Multiplus ll 24 3000
I have a Multiplus ll that has solid bulk , absorption lights on solid and low battery , overload lights on solid , with inverter light blinking… The AC side was not on nor was i running a load on the inverter when i went and seen the lights on, I took the cover off and seen that a LM324N was burnt, nothing was running at the time of failure… Is this common? Thanks And should this be a warranty issue on a 4 year old inverter?
