Hi
I am having trouble getting AC 2 out to cut off at a set soc
The sytem has a 600 amp NG batteries, Lynx ng smart bms, cerbo gx and 15kva Multiplus,
I have set the assistants up and they are fine, the issue is that the multiplus switches between the lynx bms soc and the internal soc of the multiplus as soon as the soc drops below 85% it can be seen swapping soc on the device list between what the lynx is showing,
I have the internal battery monitor switched on in the ve Configure at its default settings 85% when bulk finished and batteries are charged to 100% daily
any suggetions?
Thanks
Grant
