Multiplus-II battery SOC
Using my Multiplus-II+2, 12V system, VRM portal shows the battery SOC counting down to 0 percent in a couple days, i get a low battery warning, but the battery is actually fully charged. I have synchronized it a couple times but it still drops to 0 percent after a few days. Batteries are showing 100 percent on the BMS
Hi Ken, you are going to need to provide more detail about your system and its configuration for anyone to help.
We also have a FAQ section at the top of this category with common issues that may be of use.
Hi Nick,
Thanks, I read some FAQs. the one about all the grounds. I need to address this first. Im pretty sure that will help. Ken
What battery are you using?
