Multiplus feed in even when I disabled it
Hi, I’m new on the forum so bear with me and my English (not my native language)
I have installed a grid-connected 3-phase system with 3 Multiplus
3000/32-35, a Cerbo GX, an EM-540, 2 MPPT 150/35 and 200Ah 48V batteries.
I do not want to feed any power in to the grid thou my gridmeter cannot see the powerflow so i vill pay for everything that passes the meter
I´m running ESS assistant in all MP´s. I have disabled DC PV feed in (do not have any AC PV)
I have two problems:
1: The EM-540 shows that I feed in, as I interpret it (ex. -181W in the box ”Grid”). So what have I missed? Any suggestions?
2: No loads show up in the box ”AC loads”. All loads shows in ”Critical Loads” . No matter if I draw them from AC1 out and AC2 out, see pictures, a 1kW element is connected
Happy to provide more specific information conserning settings etc. If you need
Regards
Nicke
Is all the firmware up to date.
Is the grid meter configured in its position correctly?
Set up phase compensation to individual phase.
Thank you for quick answer.
Tried individual phase compensation with same result as before
The multis where running 508 so I will update them to 522 and reinstall the assistants and settings and try again. Othervise all firmware was the latest
Haven´t made any configuration to the gridmeter, it just popped up when I installed it. Any suggestion of what settings to change?
With the setting “individual phase” the system should try to regulate each phase individually to the grid setpoint.
Switching ON/OFF big loads are always cause a short spike from/to the grid.
AC Out 1 and 2 are both shown as “critical loads”, that’s normal.
Only loads between the grid meter and the AC IN are shown as “AC loads”.
I´ve now updated the firmware and tested the system over the weekend, its still small flutuations with feedback when i look om the remote console, but much less and there is no reverse power registrated when I look on the VRM portal so I´m happy with that. The ESS seems to be working as intended.
A another question, if I put loads between the gridmeter and the MP, vill the MP be able to feed them back thro AC IN1 and keep the meter to zero if I have enough PV and battery power?
Yes it wil! Also ess will always feed some back, because it needs grid to balance
