I just want to ask this question to verify what I am seeing is normal, or if maybe it is a component inefficiency as opposed to a victron inefficiency. I am using a 3000W 120v/12v multiplus and have it hooked up to a large battery bank. I am doing testing on the run time of a coleman mach AC unit hooked up to the inverter. When I started the test, the inverter was outputting roughly 1300W of power. After a few hours, the inverter heated up (as expected while under load) but is now outputting about 1700W for the same load. Is this normal due to the heat up of the inverter, or does this sound like an inefficiency due to the AC, or both?
Compressors will use more power the hotter ambient air becomes.
The OP is nowhere near a derating threshold. If the load is increasing it’s because more power is being used. Measurement accuracy improves the greater the reading.
