Multiplus Cycling On and Off
New Multiplus II With Smart Shunt, Cerbo GX and 24V 230Ah battery. Connected with usual cabling and Setup the usual parameters. Won’t stay on. Cycles endlessly off then a few seconds later back on. GX is reading the smart shunt data. Everything looks reasonable. This also happened with Smart Dongle and with GX with no Smart Shunt. GX seems to be communicating with MPlus. If I disconnect the GX it will stay on. Any suggestions? Thanks in advance.
Please check your GX configuration, make sure the MP2 is plugged into the VE bus port, check the cerbo pages for any error conditions flagged?
Thanks Mike. No errors. MP2 plugged into VE.bus port. GX sees MP2. Updated firmware today. Tried most ChatGPT fixes, still cycles.
Have built a couple of Victron systems in the past with no problems. Tried a couple of different new network cables no change.
! Ha.
try resetting all system components to factory default settings and try re-configuring again.
