Thanks, this explanation was extremely helpful. I think I understand the concepts much better now, although I may still be misunderstanding some aspects of how split-phase behaves when connected to single-phase shore power through a standard RV dogbone adapter.
What I am now trying to better understand is this:
With a standard 50A-to-30A RV dogbone, both L1 and L2 are effectively fed from the same 120V source, correct? If so, do both MultiPlus units normally see valid AC input and transfer/charge together even though true split-phase 240V is not present?
If that is the case, then I may have misunderstood the practical effect of disabling “Switch units as group.” I originally interpreted it as allowing one MultiPlus to accept shore power while the other remained inverting, but now I am not clear under what real-world conditions that would actually occur in a typical RV setup using adapters/dogbones.
My actual use cases are:
- Storage with a very limited shared shore source
The storage facility installed a single 20A circuit shared across four RV spaces
Technically that works out to roughly 5A per RV, but considering continuous-load guidance I am really trying to behave more like a good citizen and stay closer to ~4A continuous
I still occasionally want to use the RV normally for a few hours while there
I am fine with the battery bank carrying most of the temporary load
I mainly want the system to slowly recover whenever loads are reduced
- Moochdocking at friends’ homes
I intentionally limit what I pull from any single household circuit
My thought was that a Smart IP43 12/50 on a completely separate circuit could provide additional charging capacity into the battery bank without increasing the load on the primary shore connection feeding the MultiPlus units
- Supplemental charging while driving
Potentially powering the IP43 from the truck during travel days
I realize 50A DC is not huge relative to the system size, but it still seems potentially useful as supplemental charging
Regarding the DVCC side of this, thank you for pointing out the limitations there as well. I do understand that the Smart IP43 would not participate directly in DVCC current regulation and that the Lynx Smart BMS would only really be able to control it through the ATC output as an on/off mechanism.
I had already been exploring using the ATC output to disconnect AC power to a Blue Smart IP22 12/30 charger through an external relay/contact setup. However, once I priced out the relay components, enclosure, wiring, protection, and the additional installation complexity required to do that cleanly and safely, the total system cost and effort started approaching the cost difference between the smaller Blue Smart charger and stepping up to a Smart IP43 solution anyway. Once I also factored in installation labor at typical shop rates, the economics started favoring the cleaner integrated approach pretty quickly.
At that point, the Smart IP43 12/50 started looking attractive not simply because of charge rate, but because it potentially simplified the overall system architecture while also supporting multiple use cases.
That is part of why the IP43 seemed attractive to me:
higher charging capacity
simpler overall installation
more compact overall solution
fewer external relay/control components
potentially useful across multiple scenarios instead of solving only one narrow problem
At this point I am mainly trying to determine:
whether I am misunderstanding how the dual MultiPlus units behave on single-phase shore power in the first place
confirm whether the IP43 approach is actually a reasonable fit for these use cases, since it sounds like it may be
whether changing the VE.Bus “Switch units as group” behavior would materially help in these specific scenarios
