Multiplus 24 3000 to trickle charge AGM battery
I have installed a MultiPlus 24 3000 running 2 x 200 Ah 24V LiFePo batteries. Truck is 12V AGM. Looking to use the trickle charger built into the Multiplus to maintain charge on truck starter batteries, but being 12V and the MultiPlus putting out 24V… Is it advisable to use a step-down converter between the MultiPlus and the truck starter batteries to take the 24V down to 12V? Not sure if the MultiPlus was built to handle such a configuration. Anyone who has done something similar with experience?
This link explains how the trickle charger works. You could put a step down on it, or just use a separate 24V to 12V DC to DC charger. The link also raises some concerns regarding lithium as the source battery. May give you some good for thought.
Thank you, much appreciated for the details.
