Hi
I’m running a MultiPlus 24/3000/70-16
6x 330ah AGM batteries
On my off grid property and I’ve noticed when the multiplus goes into charging mode when my Genset is on. While on storage/bulking cycle it doesn’t seem to charge the batteries. If anything the SOC seems to slowly go down. Voltage goes up and the Genset loads up.
Kicks out about 1200w-1600w on the Vic app and I can hear the Genset load up.
When the system is working off-grid via solar the SOC and voltage go up correctly.
The solar is connected directly on the 24v input (not on the batteries) so can rule out main cable fatigue.
Anyone had any issues like this before?
Many thanks Gaz
