Multiplus 2 charging function
Good evening
I have purchased a Multiplus 2 10kva unit and will be running my house from it shortly.
I have an external battery charger for my battery to charge up during under performing solar days.
My question is with regards to the charger function of the Multiplus. If I connect it to the mains/grid supply will it charge my battery whilst the Multi is inverting to my house supply?
Many thanks
It cannot charge and invert.
It will charge and pass through power from mains to the house if the input current limit is set high enough to allow both.
