My Multiplus 12/3000/120 50A, has a green led mains on, a yellow bulk led on, an inverter on green led on, a low battery red led on. I read 12V in the main dc from my link distributor 1000, but I read 0 V on my 120V out put (connected or not connected to shore power). The battery charger is not working from my Multiplus unit (the batteries do charge though my Orion or through solar). I also noticed that my link distributor 1000 has no led readings. I bought the unit in 2024, I installed the unit in Aug 2025, used it continuously for 6 weeks without any problems. I took the batteries out for the winter, I installed the batteries last Thursday, all my low voltage appliances work, but I noticed the next day that my 120V inverter voltage was not working. I would appreciate any suggestions, including if anyone knows if the unit has a warranty. Thanks
Related topics
| Topic | Replies | Views | Activity | |
| Multiplus 12v 3000va | 2 | 69 | June 3, 2026 | |
| Multiplus 12/3000/120 not responsive | 0 | 155 | December 14, 2024 | |
| Multiplus 12/1200 12v and 230 vac are good but no power | 0 | 10 | August 11, 2026 | |
| Multiplus 1 not inverting 12V to 220V - 12/3000-120 | 2 | 61 | June 1, 2026 | |
| Multiplus 12/1200/50 not charging batteries | 7 | 250 | July 19, 2025 |
