I’ve got a multi voltage, multi inverter setup on my boat. It has separate Quattros connected to the same battery bank where one is 230v/50hz and the other is 120v/60hz for universal power when traveling between countries with different standards.
In the new UI, I can see and control both inverters which is a big improvement.
There seems to be a bug where it is only showing the load on a single one of the inverters on the ‘Brief’ and ‘Overview’ pages for AC Loads. It would be very nice if it would instead show the sum of all inverter AC loads and then let you click to drill down and see details of each unit if needed. Right now both of those pages show incorrect data because one of the inverters is hidden.
