Multi RS40/6000/100 Hybrid Inverter
Hello all,
I planning to use 1x GX, 2x Multi RS 48/6000/100 parallel with Lif4 battery’s. and 23Kwp panels.
In the first states of this system , is will by have 1x GX and only 1x Multi with 1x 48V 314Ah battery and NO dc in from Solar panels. (Wait on permission from government, with take time….xyz.).
Question, is it possible to set the Multi RS to charge the battery in the night from 10:00pm to 05:00am (stop charing by 80% or 90% soc in this time frame), as there energy have the low cost ?
mfg
Andreas
Hi yes you can when you setup ess, there you can use scheduled charging
tanks
Thanks
The Multi RS as of today does not support parallel. You say only 1 in the first, but don’t be disappointed if the second phase is not possible.
Yes I see, thanks . May I will use the smart version, is can 12 in parallel and the dc current is better (18/20a).
