Hello, I was thinking about buying the above mentioned inverter charger and was curious what the second AC output can be programmed to do. For example, if I had a breaker box with a double pole main breaker in the middle, could I wire AC1 to one side and AC2 to the other side, and have both function the same, pulling battery power when no grid is available, and providing power to both sides of the breaker box when plugged into shore power. I believe the out of the box purpose for AC2 is to only provide power when plugged into shore power, and wouldn’t pull from the batteries otherwise. Thanks.
AC2 output can be programmed either to com on when Grid/Generator/shore power is connected to AC in (Default) or the inverse: to be powered when the device is in invert mode.
The latter is usually used for stopping an AC coupled inverter feeding back to a generator. However, this use prevents the AC coupled inverter from assisting the generator to charge the battery or supply the load.
Hey Mike, thanks very much for the quick response!
Is there an easy way to use assistant to turn the ac2 out to be used the same as the ac1 out? I Have an rv and was hoping to just have a plug in running off the ac2 to power the satellite equipment. It would run whenever inverter is on regardless of shore power.
start here:
