I have a Victron SmartSolar Charger MPPT 150/45/ connected to my Home assistant through a Raspberry Pi. All works well except the reported current from the solar cells and the battery charge current are always equal.
system
▼0
▼Dc
▼Battery
Current = {“value”:21.100000381469727}
▼Pv
I do not beleive that this can be true, If it is then the charge cntroller should be red hot dissipating the excess power from the cells.
What it reports here is the total PV battery current. The PV current coming from the panel is not available, only the voltage and power. They are only available at the MQTT topics of the solarcharger (solar/../Pv/Y and solar/…/Yield/Power).
Just asked a question regarding the availability of PV current as I hadn’t seen your reply here. So I suppose the question is why isn’t PV current available and is it something you could publish over MQTT?
