it’s may be a bug introduced with 3.50.
My victron setup is not connected to the grid.
Setup:
3 multiplus II (48/5000/70-50)
11.4kW (peak) panels connected to Victron SmartSolar MPPT RS 450/200
14.4 kWh battery (JK-BMS connected via serialbattery to the victron system)
NO grid code on the multis. The system is off grid.
Venus OS 3.5
MPPT FW 1.7
Multis FW 522
Since the upgrade from VenusOS 3.42 to 3.50 the AC out frquency mqtt topic is not published anymore.
Please ignore my comment about my actual frequency problem. This disapeared and was caused by not setting up the charger in the multis correctly. (I introduced AC coupled solar the first time into my setup…)
as obviously nobody else observed this bug it is no bug.
The frequency mqtt topic is back.
I am still using VenusOS 3.50.
The only change: Update of the gui-mods to version 10.76. Now they are back in 3.50:-)
I am a big fan of the gui-mods by @kwindrem . This is one reason I still prefer gui-v1 over the version 2.
