Which voltage is used for Battery and Load On/Off?
Config:
BlueSolar with VE.Direct Bluetooth Smart Dongle (7 years old),
now new additional:
SmartShunt 300A
SmartBatterySense.
- all updates made.
Network installed, in Config it says MPPT is using voltage from Shunt and temp from BatterySense.
So far so good, but…
due to some change in my system I made experimental tests of the operations.
First thing i recognized was strange behavior of the load-output. My setting for for the test is Load On >13.00 and OFF <12.90 Volt
No i have two voltages applied 13.20 to Batt of the Mppt and (Batt MPPT reduced by 0.50V) 12,70V to the shunt.
After 2 Minutes (Some hysterese-time) the output switches On !!. (Eventhough it should not! with voltage below 12.90V given by shunt)
if i open the apple Victron App it shows all network devices. There i can see MPPT with 13,2xV and Smartshunt with 12.7xV
Load output still On!! (MPPT shows 13.2V instead of 12.7V what it should be, using the voltage from Shunt.)
If i lower voltage MPPT to 12.8V (shunt at 12.3V) then the output switches off.
Opposite direction same result: I increase MPPT Batt to 13.2V (Shunt at 12.7V) Output switches On. Which is wrong again.
This shows me that at least for the load output the shunt-voltage is not reference.
But what is with Battery-Loading setting voltages? Is it taken from shunt or MPPT?
It should take reference from the shunt, but after my small experiment, i am not really sure….
Thanks for your opinions.
