we are using MPPT 250/100 VE can in a commercial space for a communication shelter
The scope requires batteries to be installed externally away from the Comms Shelter
In the MPPT solar charger manual it states the controller to be mounted no less then 3m away from the batteries, is this critical to the performance of the charger and batteries?
system design will require the controller to be mounted in a separate room and 7m + away from battery location
