MPPT Overcharging Pylontech
So individual connections to the bus bar?
Has the mpot been programmed with 51v float and 52v absorption with a lithium profile?
Like this?
Summary
It is important to do this for all the inverters when you feedback all charge current limits in DVCC are ignored.
Possibly something else you can try is disable the internal chargers in the inverters and set their charge curren to zero (using ve bus configuration)
yes, now there is no overcharge problem by now. Voltage seems as rock for 52v around. So is good.
But still problem is with ESS and self consumption, because there is no an consumption. Only keep fully charged. And there is not choiced that way.
