I’d like to be able to turn on battery heaters only when the input solar voltage reaches a minimum level and stays there for a while. Due to the way the batteries are mounted, there are substantial periods of the day when the battery temperature is marginal for charging, but there is plenty of sun. I don’t want to leave the heaters running when there isn’t solar energy to charge them.
Setup is a Cerbo GX-S and MPPT 100/15. MPPT is connected to the Cerbo via VE.Direct. There’s also a SmartShunt connected to the same Cerbo.
I suspect there’s a way to do this in Node Red or maybe Signal K, but maybe someone has already done it?
Thanks!
