good evening everyone, I’m installing an mp2 with Smart shunt and cerbo gx. I would like to set a maximum charge threshold (90%) on the mp2 charger. Is it possible to do this with the victron software or do I have to intervene with an external relay connected to the Smart shunt?
If you have Cerbo GX, it means you can have Node-Red.
In there you can do anything you want, at script (software) level, without the need of an external hardware addition.
I’ve recently approached the Victron world, node red is the first time I’ve read. Is it necessary for a very experienced user to use Node Red?
Thanks for your great availability. with this system can I also stop the production of energy from dc-dc and mppt?
You can control almost anything.
Just take your time and watch.
You’ll see… ![]()
