I’ve recently added new solar to an existing system on my sailboat. Today one of the new MPPT charge controllers started beeping loudly and derated itself for a few minutes. As this happened we also lost AC power briefly, as if the inverter reset itself.
I’m thinking that perhaps the charge controller overheated but I don’t see how that would cause the inverter to reset, unless it caused a voltage spike through the busbar they’re both grounded too. The data shows that this all happened at the exact moment the system went into absorption mode.
System details
1 x legacy 100|50 BlueSolar charge controller
2 x 100|50 SmartSolar charge controllers
1 x 75|15 SmartSolar charge controller
Multiplus II 12v | 3000w inverter charger
Cerbo GX
SmartShunt
It’s on a boat in florida as it was midday with most hatches closed so it was warm (>30*C) where the charge controllers are.
The charge controller that beeped and derated itself covers the hole in the wall that all the cables run into, so lots of cables are running through the very bottom of the heat sink. Some cables are also running through the far left and far right heatsink columns, for neatness. So I’m wondering if the presence of the cables could have reduced the MPPTs ability to keep itself cool? Also, could the lack of a wall behind the unit actually reduce the airflow through the heatsink? (Does the wall help the heatsink columns work like chimneys?)
If this is an overheat issue, is it because of the cables? That would seem overly sensitive. Both 100|50s were very warm to touch at that point, but not worryingly hot. I can put a 12v fan behind the device but it didn’t feel much hotter than the one above it so I’m worried about both in that case.
And then what caused the AC power to turn off for a second? All these devices are grounded to the same bus bar as the inverter. Could that have received a voltage spike and protected itself?
Thanks in advance!
