using a 150/70 charger, worked fine for a year, now just stopped. disconnected the negs, then reconnected, charger shows bulk charging but it is not passing the charge through from the 4 200 watt solar panels. 12.5 volts are coming in from panels, nothing going out. any ideas? remote location with no connectivity.
mattclabaugh
(matt clabaugh)
1
water_rat
(klim8skeptic)
2
Sounds like you have a bad connection between your panels and mppt.
Check the wiring and all connections.
Related topics
| Topic | Replies | Views | Activity | |
| Mppt controller connected but no charge | 2 | 232 | 8 September 2025 | |
| Battery Not Charging - MPPT 75/15 | 1 | 97 | 30 May 2025 | |
| MPPT 75/15 inconsistent charging. | 1 | 174 | 3 September 2024 | |
| No solar Charging from MPPT 100/50 | 2 | 399 | 2 April 2025 | |
| SOLVED: SmartSolar Mppt 150/70: "not enough PV input" despite >70v at panels | 5 | 434 | 8 June 2025 |
