Noted - I’ll be careful not to make too many requests if there is an NVM event that occurs each time.
We would like to charge our battery pack using the MPPT as a ~46V to ~24V DC-DC converter. The battery pack has it’s own input power switch and charger ICs.
My understanding is because our device does not present battery voltage at its charge input, the MPPT won’t automatically switch to 24V mode at start-up.
That’s why I would like to issue the ‘switch to 24V mode’ serially. Later, we would like to adjust the charge current on-the-fly with serial commands also.
Based on your input, perhaps there are NVM implications there also?
Regardless of how the instruction is issued - either through VE Connect or via the ve-direct interface, it still affecte the same memory location. These EEPROM memories have a very limited number of erase / write cycles, so frequent changing of the data should be avoided. Parameters that are written into RAM can be changed much more frequently. The trick is knowing where the data is stored. If it’s non volatile, it is in EEPROM and should not be changed frequently.
