good evening everyone, I have recently approached the world of node red and I am looking for more and more information to be able to create flows independently. I would like to create a scenario that based on a certain percentage of soc, sets the multi plus 2 in inverter only mode. I would also like to be able to disable the trickle charger auxiliary output under a threshold of Soc. who can help me?
Disabling the trickle charger from node red is not possible without a smart or other switch.
What battery do you have?
I have a 204 ah 24v service battery, it is a lead acid engine battery. What do you mean by smart switch? I could also do it with a simple relay connected to the cerbo that takes information from the Smart shunt
I guess i am a little more cautious with the cerbo relay. I use it signal but not carry current.
I use ssr relay. Only minimal current will pass through the Cerbo for the microswitches. Can I create a flow to control relay 2 of the Cerbo through Node Red?
Yes you can control the relay in node red. Of course you will have to modify the code a bit.
Perfect. Json file work also the rele number 2?
You will need to edit the node. Once you paste it im sure you can work it out.
