Clarity on Victron Cerbo-S GX Energy System Control Module and connecting devices
Could anyone please help me with the following questions regarding the Victron Cerbo-S GX Energy System Control Module:
  1. Can I connect the BMV 712 via VE.Direct and use the shunt reading to trigger the two relays independently, e.g., low voltage, high voltage?
  2. Can the Multiplus 12/1600/70 be connected using a VE.Bus connection?
  3. The MPPT 250/100 can connect using VE.Direct?
  4. The Cerbo-S GX can be administered using built-in bluetooth and the Victron Connect app?
Many thanks!
