Mopeka tank sensor, auto start generator, relay 1 conditions
Hello, I am setting up a mopeka pro universal sensor on the generator I have.
i want to qualify the two wire auto start on the generator based on two conditions.
SOC < 30% and Tank level > X%. Is this possible?
using relay 1 on the cerbo gx.
setup: multiplus 2. 48/5000/70 - cerbo gx generator with two wire auto start
Not within the stock settings available with VenusOS and the generator start/stop functionality. But, you could do this with NodeRed.
If you don’t want to use NodeRed then configure generator auto start/stop with SOC and set up a separate alarm on VRM to send you a notification ahead of time when the propane tank reaches a low threshold.
