Is there a Setting for Temperature Coefficient that I can change via the Mk.2 Interface. I note that it can be changed via the VE-Configure software and the Mk.3 USB interface.
Related topics
| Topic | Replies | Views | Activity | |
| New UI change temperature ranges | 14 | 307 | 18 November 2024 | |
| Offset Temperatur Sensor am Cerbo GX | 6 | 208 | 15 May 2025 | |
| Temperature sensor voltage change when upgrading pre-2024 Cerbo to MK2 | 0 | 108 | 18 February 2025 | |
| Use of MK3 interface USB and connect | 48 | 667 | 9 February 2026 | |
| Passwort Multiplus II mk3 usb adapter victron connect | 1 | 397 | 1 November 2025 |
