Hi all
My system is:
2 Victron Multiplus 48-5000-70 working in parallel
1 SmartSolar charge controller MPPT 250 100 - Tr VE.Can
15 SunPower panels 325 Wp
1 Color Control GX
4 Pylontech batteries US2000 2.4 kWh 48V
I have two questions:
- On the VRM portal, since a couple of weeks ago, I can’t see the option to access the remote console. I have check the configuration on my Color Control and the remote console is enabled and the status is Online (I have reboot the color control just in case, but is the same, I can’t see the remote console option in the Vrm portal).
- Under notifications, I have an alert: mk3 firmware needs update. Under the device list, on the MultiPlus, I have a pending update for MK3. My question is if is safe to do this update. My worry is about the parallel configuration of my 2 Multiplus. If I update, the configuration will be kept afther the update?
Thank you so much in advance.
Best regards.
Carlos.
