Hello
Sur le VRM il a été rajouté dans le Widget BMS Min/Max cell voltage le fait de voir quelle unité est concernée et c’est une bonne chose.
Malheureusement, par pour ceux qui ont 10 unités…
L’affichage devrait être un truc comme 010A … 010F
Voyez par vous même :
What is displayed there depends on what your battery addressing system sends. (So firmware related - mentioned in the release notes.)
Does the system on the GX give the correct information?
Hello X
Thanks for your support, yes in the battery details on the Cerbo the display is correct here:
Do you have more than one stack?
only one
Interesting how you have a mix of lettering and numbering on the address system. Have you got a mix of models on the stack?
from 10 units it doesn’t matter if they are the same or not the Pylontech numbering is 010A, 010B, 010C… So it would be good to have the same feedback in VRM as exists in Cerbo.
Why i ask, is mine is labelled 101, 102, 103. So was wondering why your units use letter?
yes it’s the same for me the master is 0101 and the others 0102 up to 0109 but at 10 units you pass with a letter. The 0110 does not exist it is named 010A.
@maa
Can you test again? It looks like there was bug in the VRM.
@lxonline
That’s perfect, your correction worked, thank you.
