Managing "PreferRenewableEnergy" Sustain mode from Node-RED
I’m very happy to use PreferRenewableEnergy Sustain mode on my sailboat. Not to save on Grid cost but to be able to keep the battery more or less idle att ~70% (13.2V) when the boat is not in use.
BUT: The logic for interupting sustain mode is the exact oposite of my needs:
When I’m actually using the boat, I want it to be as fully charged as possible whenever I have shorepower. So when I choose to “Charge to 100%”, I want it to stay that way until I restart the Multiplus or otherwise reengage PreferRenewableEnergy.
On the other hand - if an automatic full charge is triggered, I’d like the batteries to go back down to 13.2V after the absorption cycle is finnished.
So: This could be a feature request for a setting in the VE Configure app for sustain voltage to choose interrupt sequence:
  • After manual full charge: Either “Revert to sustain mode” or “Remain at float”
  • After automatic full charge: Either “Revert to sustain mode” or “Remain at float”
OR: Is it possible to do something abut this in NodeRed already??
The “PreferRenewableEnergy” in the VE-bus system control node can be set to 1 or 0 from NR - but setting it to 0 only triggers the one-time full charge. Is there a way to deactivate the entire “Sustain Mode” voltage limiting from Node-RED? Maybe from the Custom Control node?
Seconded
