I recently got my system fully completed and been keeping an eye on things to ensure its operating as designed and within spec/limits. The Lynx Shunt 1000, I have a the power in Class Ts on the left side w/ 4x 16kWh batteries each with 225a fuses and right side i have the distributors with a RS450/200 and MP2 15000. So my max discharge current is around 200a and charging current can be as high as 400a in perfect scenarios. I have a 800a CNN fuse in the shunt currently and a temperature probe on the terminal and when I get north of 300a the temperature gets to around 106 F and seen it as high as 110F. Is there any value to having a fuse here with all the other fuses I have on the system? The shunt came with a bus bar to place inside vs a fuse and assuming that will remove the bottleneck of the fuse creating the heat.
Related topics
| Topic | Replies | Views | Activity | |
| Lynx Shunt VE.Can, fuse type | 5 | 287 | 18 March 2025 | |
| Why is the Lynx Shunt disliked so much? | 4 | 421 | 5 October 2025 | |
| Lynx Shunt fuse for continuous 1000A | 2 | 200 | 25 November 2024 | |
| Lynx Shunt max ANL fuse for 3x Multiplus 2 15000 48V | 9 | 192 | 21 July 2025 | |
| Class T Lynx Power In (M10) to Lynx Shunt (M8) or Class T in Lynx Shunt | 0 | 167 | 25 June 2025 |
