Looking for an installer in south east London (UK)
Not sure if it is the right place. I’m on the lookout for a Victron installer around south east London area. Needs to be MCS registered so I can keep my FTI tariff ideally as I have a 2.1kw allowance and that sounds better than exporting at 15p.
Have you tried?https://www.victronenergy.com/where-to-buy
yes, but that is where to buy, now who to install. I’ve called the shops, they just sell the kit, they don’t install it. It should be easier to find an installer.
You can filter for installers. Maybe there isn’t one around the corner, but it should show some options around the UK for you.
no one around here, nothing. Closest is 2 hours from London. they may be more likely to go France and get some cheese and wine than come to the big smoke.
Did you ever manage to find a London-local(ish) installer? I’m just starting to look and running into the same challenge…
I ended up using an electrician that does solar panels, but I sourced all my kit from another person that advised me on victron gear, and then the electrician followed the plan and I paid for the labour. It was a bit of a mission but I got what I wanted.
