Hi, are there any Victron engineers in or around the East Anglia area? We have an off grid system, installed 2 years ago by a local electrician, which we are now looking potentially to connect to the grid, to charge batteries etc. any help would be appreciated.
Regards, Kelly
Did https://www.victronenergy.com/where-to-buy not help?
Hi, thanks for your reply. I have looked at that but unfortunately it only shows a supplier but no engineers within my area of Cambridgeshire.
Might be worth calling a supplier, they might be able to refer you to someone. Worst case you waste a phone call.
You maybe able to firstly use the same electrician to do the G98/G99 notification/application as appropriate, then connect the AC in line with the regulations and then get someone who can do the ESS setup remotely if the system is connected to the VRM portal. Happy to advise on things such as ESS, energy meters, fully type tested certified equipment etc. which I hope the local supplier should also be able to do.
