I am wondering if it’s possible to always exclude the EV charger (wallbox) from the battery. So that the wallbox always charges from the grid and not the ESS? I can’t just change the Grid Setpoint because as far as I know that will also mess the Dynamic ESS predictions/control!
We can’t put the EV charger on the AC In side because we still want the option to be able to charge the car when in backup power (besides that it also isn’t possible electrotechnical). So if there ever is some reason for which we need a fully charged car, we simply can flip a switch (in/with Victron/Node-RED/Loxone) which enables the charger again.
There is a whole smart home system (Loxone) besides Victron. Loxone uses Modbus to only follow Victron (not control at the moment because we use the DESS) and is in control of the Loxone Wallbox. Is it possible to use Modbus (or another protocol/Node-RED) to exclude the EV charger? As example: to (temporarily) limit the Dynamic ESS/Victron discharge power or maybe with another solution. If not, would above situation be possible with a Victron EV charger?
