I think you should probably create some threads for dedicated issues, provide some data and relevant settings and a lot of the enthusiasts around here will have prompt solutions or improvement suggestions.
Just a general “it’s not working as i expect” is neither phrasing a concrete problem to look at, nor allows to suggest where to start…
This for instance alone can have many many many reasons:
Solar string voltge to close to battery voltage
Peak Shaving settings requiring curtailing of production to obey limits
Simple MPPT Tracking doing a fullscan. (All inverters do that, they usually just don’t reflect that in their reported power output)
String voltage raising to high, making the MPPT going into overvoltage protection.
String current raising to high, making the MPPT going into overcurrent protection.
Thermic throttling on the MPPT
Thermic throttling on the inverters requiring curtailing on mppts to avoid overvoltage of the battery
I absolutely agree - but the case that there are systems NOT showing this issues also disqualifies the thinking that “it’s a general control / architecture problem”.
Yes, there have been bugs in firmwares and control-logic. There are some presently. And there will be new in the future as well.
Overvoltage and overcurrent are btw damn hard to identify - because the MPPTs are exactly avoiding that to happen at all and stay within specification. (Which just means, measurement data won’t show this, external measurements won’t show it as it is literally prevented to happen to avoid damage)
I understand your point, and I agree that not every issue automatically means there is a fundamental architecture problem.
But at the same time, the fact that some systems work perfectly does not automatically invalidate the experiences of many others either.
In my case — and in several very similar installations I personally know:
the systems operate within specification,
temperatures are normal,
voltages are normal,
currents are within limits,
and yet the behavior still appears mainly near full SOC and ESS coordination scenarios.
That is why many users suspect there may be a combination of:
firmware edge cases,
ESS state-management behavior,
AC-coupling interaction,
and specific real-world operating conditions.
I fully accept that some problems are configuration related.
But when:
multiple experienced installers,
similar hardware combinations,
similar ESS topologies,
and similar symptoms
appear repeatedly across discussions,
then I think it is fair for users to question whether there may still be unresolved ESS/software behavior involved.
And honestly, I appreciate this technical discussion much more than simply pretending the reports do not exist.
The community is not a real barometer, it has skewed representation.
There are literally millions of systems, here it is mostly biased to a small diy and self-install sub-section.
The vast majority of issues are self-inflicted.
Sure we solve real issues, but those are quite apparent and get addressed and are a minority, beyond betas.
You may also notice the community trend of members tagging themselves as expert and professional, when the topics posted clearly show the opposite.
Large scale flaws get addressed, there simply is way more work happening behind the scenes beyond this community.
I understand your point regarding community bias, and I agree that forums naturally attract users experiencing issues.
And yes — many DIY/self-installed systems certainly have configuration mistakes.
But at the same time, I do not think it is fair to assume that most reports automatically come from inexperienced users or fundamentally broken systems.
There are also:
licensed PV operators,
long-term ESS users,
and professionally maintained systems
reporting similar behaviors in certain ESS scenarios.
In my own case:
the system is professionally configured,
monitored long-term,
and even accessible directly by Victron staff through VRM administrator access.
So I fully agree that forums are not perfect statistics — but I also think repeated reports from experienced users should not simply be dismissed as “community noise”.
Especially when many of the discussions revolve around very similar:
