L1-L2-L3 setup
Not relevant anymore
As per the docs, you can’t mix models in parallel nor multi-phase…
This is the option that will work, out of the three mentioned.
Are you connected to the grid? I have AC coupled a 12V 1200va and a 24V 1200va to a 5000mp using ESS. It works perfectly with some setting up. It required some node red control.
