I just finished installing a Multiplus-II 3000 12v in my RV trailer. My shore power plug feeds directly into the 120v-IN on the Multiplus.
I never really thought about it until I finished my install, but if I was to hook up to shore power at an RV park and run the air conditioning through a 30amp shore power supply, is this something can safely be done for many days on end? I assume (hope) the Multiplus can handle this.
That reminds me of another question. I’ve read a lot about proper cooling. But I haven’t seen anything saying what is a recommended maximum temperature for the MP2?
The Datasheet says it will start derating output power above 25°C, with output values provided up to 65° ambient.
The temperature derating calculator app says power will be 0 when >65°C so I’m going to guess that’s the hard limit
The general rule in electronics is that any rise in temperature with 10° will cut a component’s lifespan in half.
So better to keep 'em closer to 25°C than to 35°C (or higher).
