Is there a way to display vertical gridlines?
I guess this might be feature request. I rely on the graphs in VRM Advanced to map changes in voltage and amperage in my system based on the state of the various devices. But this is rendered difficult because there is no visual time clue between the various widgets graphs other than the time stamps at the bottom. Having vertical gridlines would make it much easier to determine when two graph lines cross, when specific events happen, etc.
Along with the above, the ability to overlap a “State” graph (e.g. the MPPT state or Orion state) on a graph of voltage and amperage would be fantastic!
Hi not what you’re asking but I use the zoom feature, but I hear what you’re saying…
Yep. That’s what I do also, but sure not as convenient as having vertical gridlines. Hopefully, someone from Victron will see this, along with the request to overlay state graphs.
