Is a SmartShunt redundant with Lynx Smart BMS?
Hi
If I have a Lynx Smart BMS 500 NG, should I also add a SmartShunt to my my system, or does the SmartShunt become redundant?
Is there any additional monitoring capability or accuracy provided by having both the SmartShunt AND the Lynx BMS?
Thanks
The Lynx BMS has a builtin Shunt, adding another one would be redundant.
As for accuracy, i assume they are comparable, but have no real data. You would need to run both in the same system to compare.
