IP67 12V/17 amp charger kick back in to bring up to full charge?
When LiFePO4 battery is in storage mode when or what voltage does the Smart Bluetooth IP67 12V/17 amp charger kick back in to bring up to full charge? Voltage on battery meter is showing 13.41 volts but only 81.5% SOC when charger is in the storage mode?
Did you had a look into the VictronConnect App?
There you can see the current configuration and all the voltage levels. You also can configure a rebulk current. This setting is hidden, go to ‘Settings’, enable ‘Advanced settings’, there enable ‘Expert mode’. Than you see in the ‘Bulk’ Section the ‘Re-bulk current’ when this current is reached the charger goes back to the Bulk mode.
Best regards
When I make changes in the advanced setting can I go back to the standard configuration settings later?
You can create a custom profile for your test.
The standard presets remain unchanged.
