Are Blue Smart IP67 voltage settings adjustable?
Are the Blue Smart IP67 voltage settings (float, bulk, absorption) adjustable in 0.1V increments in a custom profile? The data sheet gives one the impression that are only three selectable voltages (normal / low / li-ion).
I have an AGM battery which specifies a float voltage range of 13.4-13.6V. However the data sheet specifies Normal:13.8V / High:13.8V / Li-ion:13.5V as the float voltage. Is it possible to adjust to a lower float voltage than 13.8V for an AGM battery?
The IP67 charger has factory default charge settings for the different types of batteries.
If you want to make your own settings, then you choose the ‘advanced’ settings in the Victron Connect app menu, and set all the different values like you want them. Bulk, float, and absorption voltages can be set per 0,1V indeed.
