Hi all, i’m a beginner in Victron integration in marine. My installation :
- IP43 SMART CHARGER used when in marina
- n.2 solar Victron smart solar charger
- n.2 ORION XS in parallel to charge with the engine alternator
- BMV-702 battery monitor
- n.1 Smart shunt used as CC counter
- n.1 OEM INVERTER
The issue is related to the CERBO GX GUI . i expected to see the IP43 Charger in the GUI(into the box dedicated to MULTI , but it is not. i read something related to a Victron integration illimitation which forgot to add IP43 in the GUI.
i also read (i was unable to find again) that there is a workaround changing software to present IP43 Charger to the GUI as a MULTI.
Hoping someone can provide a more clear picture and hopefully a solution.
Many thanks in advance for support.
Marcello
