Charger - BatteryCharger 50A [279] Error: Err 20: Bulk time limit reached
Yet the charger has only been on for 3hr 48m.
I changed the Bulk Time limit from 10hr to 12Hrs, but this did not fix the problem. Normal operation only started after I turned off Bulk Time.
Is this a firmware bug??
I have not seen this again.
I spent a couple of hours turned everything off and restarted Cerbo GX, checked firmware for updates (none).
I turned off the circuit breakers to all inputs and outputs.
I found changing the Bulk Time Limit had no effect on the error codes generated.
I have installed two AC/DC chargers a IP22 12/30 and a IP43 12/50 1+1, which have been working fine together up to this point in time.
I have not had this problem since this event in February.
