Ip22 12v 30amp smart charger
Can this charger be used for two 6v batteries connected to be 12v? 100ah? Lead acid bath. Just to be sure and not to damage new batteries. Golf cart trojan and rolls (red tops)? Thx in advance
*** found the spec sheet for the flab rolls. Answers are there . Thank you everyone. Not sure why i missed the obvious. Getting old i guess. Thank u all.
You can use it, however you should reduce the output power in settings down to 10 or 12 amps. Also check the voltage settings as Trojan require higher voltages than normal Lead acid.
Thank you all.
I retract my comment about turning it down I was being conservative.
50amp recommended just let it run it will just take a bit longer
