Inverter VE.Direct auto restart
Hello all,
I am off grid and interested in the victron Inverter VE.Direct and I am wondering, if my battery goes to zero power ( which happens on the rare occasion when we have weeks of heavy clouds ) and the system shuts down, will the inverter auto restart when the solar panels charge the battery back up again . The current inverter ( not victron ) I have requires a manual restart and which is a problem when I am away for weeks and I need my security system back up and running.
Also wondering if there is a problem with connecting two inverters to my battery that will be on separate circuits ( I have a Victron Energy SmartSolar MPPT )
thanks in advance for any help and info that can provided.
Larry
I am in the same situation. On the Phoenix 1200 which I am running on 24v there are two settings:
  1. Restart/Alarm
  2. Low Voltage shutdown
    I can tell you from recent testing that the inverter will stop inverting if the Restart/Alarm threshold is crossed and restart when it goes above the setpoint.
The caveat is that I think it should be shutting down at the Low Voltage Shutdown and restarting at the restart threshold. Otherwise you will get in a hystersis loop since taking the load off a battery (in my case sodium silicate gel cells) will cause the voltage to rise restarting the inverter and the cycle over again every few minutes.
Thanks for sharing this information and the note on the Loop problem. Very helpful to know. I just got the inverter and just that it auto restarts when I turn the battery off and then on again is great, and that you can also remotely turn it off and on and place in eco mode is really useful.
