Inverter control removed from VRM? Solved
At the moment I can’t see inverter control in the settings button in upper right corner. Running v3.41. Also in my urge to switch off I couldn’t find my devices in the Victron App for Iphone. All devises gone in the VRM view.
Luckily I could switch off the inverter in the console view in the VRM Portal.
Solved: The option “Enable two-way communication” was switched off for some reason. Enabled and everything ok :slight_smile:
Requires a realtime connection, and check that it hasn’t been disabled in your VRM settings.
