Is there any possibility(victron approved) to get inverter signal(24v or 230v) out from inverter/charger to install external inverter pilot light? Didn’t see any option using i.e aux or alarm relay.
Thank you i.a!
Thank you i.a!
I run 12V LED Pilot lights straight off the Multiplus II 12V Aux output. You can either use the open collector or MPII relay with assistants, or via the Cerbo relay for better Node RED logic.
How do you configure the aux relay/alarm relay for charger only setting on MP-II? I could not find a setting for that using mk3 on set up.
N, 17. juuli 2025 10:18 Deon Korb via Victron Community <notifications@victron.discoursemail.com> kirjutas:
