My Multi RS Solar is now showing an “Internal AC input monitoring” alarm which is stopping it from connecting the AC grid input connection.
This happened after a relatively large load was applied at the output, though nothing unusual. The only other thing that is noteworthy is that the RCD on the input side had tripped (which might have happened before or during the incident).
The error message requests that I try restarting the Multi which I have done but no change. The suggestion on the alarm is that if that fails then the unit is probably faulty.
The RS works fine except for it won’t connect to the grid at all which I do occasionally need if the load is fairly high although this only happens once in a blue moon.
Has anyone seen this before? I can’t find any other references to this anywhere?
Screenshots of the issue:
@guystewart is there anyone in technical that can shed any light on the above message?
If not then I’ll get in touch with the company I purchased the unit from and ask them for some help.
I guess I’ll get in touch with my supplier.
Are these forums actually active anymore?
Hi John,
Some faults we may not have seen before therefor the community can’t offer much help, sometimes going back to your supplier is the only option.
If you can report back with the outcome this might help someone else if this issue should come up again.
Good luck.
I’ve been in contact with my supplier repeatedly about the above issue over a period of months and it’s not been very productive and I get the impression he’s not keen to help (I’m being polite).
Can I use a 3rd party supplier to return the unit at my cost if necessary or is there some way I can return it directly to Victron?
You can Submit a support request
