Inquiry regarding maximum cable cross-section 25 mmq for Orion XS 12/12-50A terminals
Dear Victron Support / Community,
I am planning an installation using the Orion XS 12/12-50A DC-DC charger and I have a question regarding the screw terminals for power connections.
I would like to use 25 mm2 (AWG 4) multi-strand flexible copper cables to minimize voltage drop along the run.
Could you please clarify the following points:
  1. Do the power screw terminals of the Orion XS 12/12-50A directly accept a 25 mm2 cable with a crimped bootlace ferrule (end sleeve)?
  2. If a 25 mm2 cable with a standard ferrule is too large for the terminal opening, what is the maximum recommended cable gauge with crimped ferrules, or is a pin-type reducer/terminal required for 25 mm2 wiring?
Thank you in advance for your support and assistance.
Best regards,
Alberto
